1 - 2 of 2 Posts
Took battery cables off battery for winter storage now I need to move the bike and cant remember if this black ground wire that comes attached to the positive cable was grounded to the frame or the neg battery terminal
If all you did was take the battery out then you just removed the cables from the two battery terminals (red to +, black to -). There should be a black cable attached to the battery.
If you follow the cables coming from the battery they will go to the starter relay/solenoid (a small black box with a fuse on top). From the relay the positive cable goes into the main bike harness and the black goes to the frame (for ground).
1 - 2 of 2 Posts
