1 - 8 of 8 Posts
Just buy a pressure switch and you'll keep your brake lights. You do the same when installing a Master Cylinder.
Or dont slice it u pand unclip it at the harness like i did..when you sell it put the stockers back on. How often do you brake without the fronts anyways...
+1^
the sensor has a plug that attaches it to the wire harness, just like every other electronic component.
I don't brake without the front at all. The only time I use the rear brakes is while sitting on a traffic light and flashing the brake light for cagers coming from behind.
Do you have any pictures for this.... I will really like to do it in this way.
just trace the wire from the brake lever.
i seem to remember the plug is right around where the subframe meets the gas tank under the black textured side panel.
1 - 8 of 8 Posts
