1 - 3 of 3 Posts
Hi all.
Had a nightmare and snapped a bolt in my engine case when trying to drain the water jacket when installing a new radiator. The engine area has quite a bit of corrosion so just snapped off. Not ideal!
Is it possible to just leave it in there? Or will it need to be removed? I'd rather not have to mess with it incase I mess it up and then have a major headache.
I thought about bringing it up to temp and just seeing if it leaks? Any ideas please?
223688
223689
Soak it with penetrating oil, let it sit for 1/2 hr and try above?
If above doesn't work a small drill bit and an ez-out will usually remove the bolt...or take it to a machine shop, they can get it out .....
1 - 3 of 3 Posts
