I was cleaning out some boxes, and found all of my tie-downs. They're just some generic red ones that I think I bought at Lowe's or Home Depot several years ago. They have worked fine for tying down my snowboards and my last bike (R6) for transport, but I started wondering if tie-downs are just tie-downs... or if they're more like stands. Probably not a good item to "take a chance" with. Is there a "Pitbull" of tie-downs gentlemen? Or is this a case of a spade being a spade?
K
Tie downs... like... rope?
i just use ratchet straps. regular... ratchet straps.
i don't really pay attn to brand with tie downs. rather, weight rating for them.
CTM is right. There should be a tag on the strap with a weight rating. Anything that can hold a couple hundred pounds should be more than enough since they're only keeping the bike upright and not holding the entire bikes weight.
Just remember, a fast turn in a truck will put centrifugal g-forces on the bike in the truck bed which can effectively make the weight/pressure on the strap increase. Drive carefully around corners. If the strap is fraying at all, it's strength is compromised and won't hold the rated weight. Throw it out.
Yeah, I've always heard of them referred to as tie-downs. But technically they are indeed ratchet straps.
Yeah I was conscious of the varying tensile strengths that are available, but that's helpful to be reminded of. I guess I was wondering if there was a superior manufacturer out there. Guess not. Thanks fellas!
