1 - 11 of 11 Posts
Just reinstalled a new motor in my 600rr. Hopefully everything was hooked up right, but im guessing not.
Issue:
When bike is turned on the FI light is solid
When I jump the wires and try and get a code the FI light doesnt blink it will stay solid or go away then come back
The bike sounds like it has a vacuum leak or something
When I give it gas it just bogs and doesnt rev for ****
Bike 06 600rr
Thanks
tps?
2 sensors on airbox?
D
Kickstand down, bike in neutral, turn the bike on. Tell us the code that flashes on the FI light.
kickstand is bypassed (track bike), do i disconnect the connection ?
thats the thing it doesnt flash ....
last time i went out there it was off then about 5 seconds later it came on
ok i disconnected the green kickstand connection that i have jumped
bike idled fine, even reved normal
it was a continuous 2 flash, which im guessing is
2 - MAP sensor vacuum hoses, or sensor itself
Any images on where these are
D
The MAP sensor is located on the underside of your airbox. It's either broken, or if you removed the airbox recently, disconnected from either the plug or the vacuum hose at the sensor or intake.
the map is bottomish side, of the back (by the fuel tank) of the air box
ill see if i can find a pic
ok i see the denso map sensor. so is there supposed to be a hose connected to the bottom of it ... i did have 1 extra hose that came from the little T section of hoses .. is that it ?
Discussion Starter #11
SHES ALIVE [email protected]#!#
thank you so much ... i had no idea where that hose went and was like oh well LOL
revs like a champ no FI light .... time to button it up do another oil change and test runs will be coming tomorrow around the block
1 - 11 of 11 Posts
