Really makes no difference which order you put them in. The last friction plate, however, the fingers should be rotated as to NOT be in the same grooves as the rest of the friction plates.
Just make sure you put the judder spring in correctly!!
The OD should be pointing out away from the hub
Oh yeah... make sure you soak the friction plates in oil for a little while before installation or you'll be re-changing the clutch in short order
