1 - 17 of 17 Posts
when you take the front wheel off, there is a spacer or bearing on each side, they do not look the same, one has a lip the other does not.
Now, when I took off the wheel I did not notice them until they feel out, i think i got them on the proper side but the on with the lip does not go all th way flush to the wheel. Is it suposed to be like this or should it be flush?
i know this much, does the one on the right side of the bike fit flush, the left when in place is fluch, the right however lacks 1/16 or so from fitting flush with the lip of the spacer.
thanks that is all I needed to see, there is a very small gap between the wheel bearing and that spacer, maby you thought i was talking about between the spacer and the fork. In this pic. you can see the lip, then a space then wheel bearing. The back side does set flush with the fork.
Thanks for the help,
Ashton
1 - 17 of 17 Posts
