1 - 9 of 9 Posts
I'm at the track and my speedo is reading 0mph. Everything else on the dash works. Just installed a PC5. Anyone know where the speed sensor connections are? Pics would be awesome. I hope it's not under the tank...
Sent from my SGH-T959 using Motorcycle.com Free App
Did the speedo work before installing the power commander? I know when I installed my speedodrd it was a simple plug and play and is not too far off of where your injector plugs are. You may have bumped/tweeked the connection while installing your PC5. Also, if you're at the track try not to worry to much about the speedo just focus on your lines and body position.
Yea worked fine before. Figured I must have disconnected to get to the injectors. Just wanted to know if it would be easy to get to. I don't look at the speedo just happened to notice it was at 0 when I was riding to tech. No big deal, I'm just picky and would like everything to be as it should. I was probably just gonna wait till I get home anyways. The bike is running great so I hope i'm right and it isn't something else.
Main reason I want to figure it out it because the hesd wont come on because it thinks im going 0mph
I believe its on the right side. 1 pin white connecter with pink wire. Check and make sure its not disconnected. Did it on a buddies bike with out knowing
Sent from my ADR6300 using Motorcycle.com Free App
Ahh that would suck. I think it is something very minor. Once you get home I am sure you will find the problem. I have an 06 and the plug was pretty easy to get to, I don't know about the 08's
I think you forgot to plug in the speed sensor as part of the subharness. I did the same, and I got no speed or mileage on the bike increasing. It's very easy to miss. White connector in the rider's right portion. See picture below. Let me know if this solved your problem.
Very interested to see if this fixes the problem.
Sent from my ADR6350 using Motorcycle.com Free App
Yup that was it. Thanks! Got a little over a hundred miles unregistered on the odo, haha. Now if this damn rain would stop so we can get out there...
1 - 9 of 9 Posts
