1 - 8 of 8 Posts
has anyone used the speedo healer on there stock sprocket set up to correct the facory reading i used the speedo calculator and it said with the factory gearing of 16/43 i should set the healer at -6.2% is the factory speedometer off that much or not
Im pretty sure that even stock, the readings are off...you might as well get one..its only 80 bucks
Discussion Starter · #3 ·
ya i got the speedo healer was just wondering if the stock odo was really off by -6.2% that's what the speedo healer calculator told me
why would it be off that much stock... thats weird
G
Mine is off by about that much, and it's stock.
when i'm going 32mph, the local speedtrap nails me at 30.
so that's 6.7% actual error.
i think there some sort of guideline for manufacturers, even cars, that says they have to overstate the actual speed of the vehicle in order to promote safety. I know that porsche overstates their speedo's by about 6 percent. That way when someone wants to blast up to 100 they aren't really going that fast.
just my .02
1 - 8 of 8 Posts
