The following indicators on the 05 600rr gauge don't work:
Turn signal indicators never change
Fuel gauge level dont change
FI light don't come on on startup
Backlight does not come on at all
any ideas? I got the wiring diagram but Im a noob with those.
I am NOT getting power to the sub harness plugs....thus I don't think its a gauge problem.
The actual turn signals DO work.
Search around for "yellow connectors" - where the grounds come in together. There's a couple posts showing pics of what you're looking for (yellow plastic with a bunch of green wires coming into it).
If you've got a voltmeter, check your supply with the black lead right at the battery neg terminal or the frame, if this makes a difference then you've got a ground problem.
OK i replaced the subharness, somehow that fixed it.
Thanks for the tips tho man!!
