1 - 8 of 8 Posts
Ok, i laid my bike down. i feel like an idiot. and now my speedo doesnt work. i went down on my left side.. and the lights for the signals work, the brights light works, but the tach, the speed, the gas, neutral light and the tripometer doesnt display. its like the bike isnt on.. but the signal and brights light work... anyone help me out? i saw a little fuse pannel thing on the left side and maybe i knocked something loose... im gonna dig in tomorrow but would like some pointers before i get my hands dirty
7amp fuse on the left side. common when you lay it down. and reset the lean angle sensor.
10 amp fuse. It should be the 3rd or 4th one from the bottom. Is your whole instrument cluster out?
The whole thing. like the bike is off.. but the lights for the brights and signals work. the neutral light does not work. is the fuse loose or blown? does it need to be replaced? how do i reset the lean angle sensor
If you look in your fuse box it comes with an extra one. I believe... mine did. All you have to do is loosen the left fairing it only takes a second. I would replace it... Do a search on the sensor I have no clue with that.
LAS turn key on with all fuses good, then off for 10 seconds, then on.
Where do i find the fuses? i see there are 3 right under the left handle inside the fairing.. and there is a little rubber thing with some inside. is that all? Which one do i need.
Those are relays under the left ram air cover. The fuses are under the left side cowl with that rubber flip top thingy over it. Pull them and examine them. The small manual should describe which ones are for what. If not, then look for a blown one. They are pretty obvious when gone.
1 - 8 of 8 Posts
