1 - 8 of 8 Posts
D
Pull the rear wheel off. Remove the sprocket. Install new sprocket. Put rear wheel back on.
Get Jiggy with it
would be hard to jack anything up.. unless you put your rear wheel back on crooked.... the front sprocket is one nut and I do believe there is a thread on it cause I had asked a while back about how much torque the front sprocket called for. the rear one is common sense , just take your wheel off remove sprocket and replace with new one..and tighten down the bolts in a cross pattern like a car rim or anything else.
It is extremely simply. I will look for the thread onthe front sprocket for you and let you know if i find it.
I am going to need some help putting the back tire on I am sure. I read so much about how hard it is and how it has to be perfect. I am terrified of it, lol.
Get Jiggy with it
Nah R3 don't be scared of it....there are guides on both sides of the wheel to make sure it's straight...you can do it
1 - 8 of 8 Posts
