Yeah.....what he said. Sounds like you are not getting enough juice. Also check the battery connections......one may have been knocked loose.steve2z said:Check voltage on battery- then check connector for the kickstand and BAS- also, check fuse for starter.
i second thissteve2z said:Check voltage on battery- then check connector for the kickstand and BAS- also, check fuse for starter edit- infact, check the fuse first.
