Hey guys I have a cbr1000rr motor I'm looking to test compression on. The motor is off the frame, no harness or anything hooked up.
I was wondering what the process was to get it to turn over so I can get some readings on it.
I've got a battery hooked to the starter and grounded but I believe there needs to be switch in order to get it turning over.
Anyone know?
how did you put power to the starter?
take the positive cable from the starter and hook it up to the battery, then take the negative cable that connects to the engine and touch that to the negative terminal of the battery,
it'll spin. for sure.
are you doing it through the starter relay? or direct to the starter.
I can't comprehend how this could not work
