hello, i have a 2005 Honda cbr 600rr with 14800 miles. recently i have been having throttle issues with it bogging at low speeds/gears. one possible solution was to get a system cleaner. i bought the product HEET and added 5oz to my tank. a few days later i went to go ride and it started up. i went about 100ft and tried to throttle up and it stuttered and then died. i tired to start again and it just cranks but no turn over. i let it sit over night, then tried again. same problems. it would sometimes sound like it wanted to turn over, but would just continue cranking. now, ive done it some much my battery is about dead. i dont know what the problem is, or why it would just do this all of a sudden. now, after have tried to start so many times, my battery just clicks. please help.
First off recharge your battery and test to make sure its over 12 volts. Then test to make sure your fuel pump is priming. There are a ton of threads about this if you search around..
Most likely a fuel pump issue.
Plenty if threads around here with that info in them so search a bit.
If you have had the fuel tank off or up recently it may be that the fuel line has been trapped. This has happened to me on this bike recently and a completely different bike. All very tight under the tank and easy to trap the fuel line.
Turning over IS cranking. When an engine is running you don't tell people its turning over do you? Just wanna make sure people are clear in what they say so others can help.
I'm a pretty lady!!!
Lololololol oh **** fam you can't make this **** up lmfao
