So I have a 05cbr600 with 23k+ miles.
I bought this thing from a friend after it had been wrecked and left sitting for almost 3 years. I took everything apart and found 3 of the plugs arches were completely burnt off.
I replaced those and put everything back together. Now the pump wasn't priming. I took that apart and cleaned it up and got it to work again.
Now it starts but dies within 5 seconds or if I give even the littlest input into the throttle..
Could this be a weak pump? Or something else I'm missing?
I've gone over all the wires and connections and everything seems to have a home.
Tips?
Check to make sure that little vacuum hose next to the MAP sensor is installed on the air box
Sent from my SM-G950U using Tapatalk
