1 - 3 of 3 Posts
Does anybody know if the Steering Stem Nut WASHER is Locking or not
My bike doesnot have the WASHER and the nut keeps getting loose
The steering stem washer is a flat washer, so no, it is not a lock washer. That being said, not having the washer may still cause the nut to become loose. The triple clamp bridge is "rough" and may be grabbing the nut and forcing it to become loose. The washer may be needed to provide a flat surface for the nut to slide on without providing the friction required to loosen the nut.
Buy a new washer and check to see if the problem stops. Also, make sure that you are torquing the nut correctly. If the nut continues to loosen then you might have a problem with the bearings in the head tube. Just something to consider if the problem continues.
1 - 3 of 3 Posts
