1.did you check your tail light connector and made sure its tight ?
2.no matter what brakes ( front or rear )you use its does not
work or is one of them working and not the other ?
3. what about your other light functions is evreything working
ok or not ?
1. i did check th tail light connection few times...
2. i tryed front and rear brake but they both don't work...
3. every thing else is working all right...
Over the berm, and thru the woods, to grandmothers
Check for voltage at the connector when the brake is on. Check that the liscense plate light and turn signals are working, they are on the same circuit. If you have checked your fuses make sure they are good with a multimeter-ohmmeter. Check the connectors under the left intake cover as well as the connectors at the tailight and each brake switch.
