Hey, I usually try and get by on my own with most things but I'm hoping someone with previous experience of this might be able to help out a little.
I was up at the track last week and, after the last session, I was low on fuel (fuel light just began blinking as I rode the bike round to the van).
I came home and put my rear indicators and license plate back on, checked they were working and went to start the bike to check all was ok. The bike wouldn't start. I assumed that it was because I was too low on fuel and decided to let it go. I had some mods to do and would put fuel in the bike and take it for a test ride when they were done.
I put my HRC throttle and '07 1000RR kill switch on early this week. I followed the advice in the threads here and hooked up the wiring as follows:
'03 600RR <------------------> '07 1000RR
Yellow/Red <-----------------> Yellow/Red
Black/Yellow <---------------> White/Green
Black/Red <------------------> Black/Red
Black/Green <----------------> Yellow/Green
White/Black <----------------> White/Black
Black <------------------------> Black
Blue/White <------------------> Blue White
I popped the battery back in tonight, hooked it up and put some fuel in the bike. I put the key in the ignition and turned it to on. Here's what I get:
Kill switch set to run:
No fuel pump sound, FI light on, Oil pressure symbol, Red HISS LED, Red Error LED. On pushing the starter button, the engine tries to turn over.
Kill switch set to off:
No fuel pump sound, Red error LED, Oil pressure symbol. On pushing the starter button, the engine tries to turn over.
Both headlights work, turn signals are ok, brake light/tail light is ok, as is my plate light and my clocks are working (obviously). I've checked the BAS fuse in the fuse box. Side stand is up (bike's in neutral anyway). The fuel indicator is also working (giving a correct reading for the amount of fuel in the bike).
Unfortunately, I don't have a multimeter but I think now's probably a good time to get one! I'm really hoping this has just been caused by me being a dumbass :retard:
Thanks in advance for any help you can offer.
