1 - 2 of 2 Posts
Bought a project 06 with minor frame damage (bottom of mount snapped off.) I got a clean title frame from a 03 to replace it.
Was just wondering if anyone else here has done one from a 05 06 to a 03 04. I know there is the difference for the exhaust mounts, but was wondering if there was anything else to look out for. Or just advice in general.
The frames are exactly the same from 03-04 and 05-06. I have an 03 frame with 06 forks, swingarm and engine. The exhaust attaches to the bottom of the engine in the same way from 03-04 as 05-06 so you're good.
Since you have everything out go ahead and replace the needle bearings in your swingarm and the steering stem bearing too. If your rear subframe is damaged as well make sure to get an 05-06 subframe as the 03-04 subframe will not accept the 05-06 tail fairing.
1 - 2 of 2 Posts
