1 - 10 of 10 Posts
ok i found one for sale...2008 cbr600rr motor includes all electronics , exhaust , cluster etc. engine has 3800 miles on it. MINT CONDITION not a scratch on it. $600
i want to buy it and will try. what should i look for and is there any way to do a compression test? also will it fit into a 04 bike as i might get one...thanks for any help/replies:ciao:
I dont believe it will fit an 04, the frame and mount points will probably be different. It would make for one fun go-cart motor though :). As for the compression im not sure. I feel like you would need it secured on a stand or something before you try to start it.
ok, well a 07 engine will fit on a 05 frame right? isnt 03-06 the same and 07-08 the same?? that's what i thought anyway.. guess i could be wrong..lol
only some parts are interchangeable. 03-04, 05-06, 07-08.
some 03-06 can work, but im not to sure about a motor since the frame is a bit different. but maybe someone with actual knowledge can chime in and help you out.
07 to 10 RR frames are not even close to 03 to 06 RR frames
03 Frame
08 Frame
that is a great price... hope i can find on that cheap when I am ready to build my 2nd 08 (got a second frame cheap and couldn't pass up a sale)
1 - 10 of 10 Posts
