Just Got A Swing Arm Assembly Off Ebay So I Could Get It Powdercoated And Keep My Bike Together In The Process. The Add Said 03-05 600rr. I Have An 05. The Top Shock Mount On The One I Bought Has 4 Bolts That Hold A Plate To Mount The Shock....my Swing Arm Just Has A Solid Mount With A Hole For The Bolt....everything Looks The Same....just Wanna Know If Its The Same Or Not. Thanks.
You bought an 03-04 and you have an 05-06.. It will work, but you need everything from the 03-04 swingarm, like the axle, alignments, rear brake bracket... If you don't have all of that you won't be able to swap them.. Best bet is to sell it and get an 05-06 swingarm this way you don't have to go backwards in the transition...T
