1 - 2 of 2 Posts
Hi all...
I own a 600rr 04 and have a weird problem.
When turning the ignition on, all lights on the dash will turn on normally, but speedo and rpm spin will not.
The speedo indication will run a few seconds later, and after that the rpm needle will make its round.
Bike starts and runs normally and has no other issue.
Sometimes the needle starts from 2000rpm, will go back to 0 and then make the round.
Has anyone ever seen anything similar, or have any clue what might be causing it?
Thanks in advance,
Best regards.
It sounds like you may just have a bad connection. Check the plugs on the back of the instument cluster, maybe unplug and plug them back in.
Reactions: acd_ex
1 - 2 of 2 Posts
