1 - 9 of 9 Posts
I recently bought a 2015 600rr and I noticed the tach isn’t working at all , it doesn’t go up and down like it should when the ignition is on , it’s getting about 8-9ish volts, I took the cluster apart and everything seems to be okay, any ideas ?
You should be be getting battery voltage on the power line, is your battery fully charged
Check the voltage between the 20pin combination meter connector and earth (White/Black and ground ) should be battery voltage, ignition on
Then you need to check the Backup Line (White/Green -Ground voltage) and the ground Line (Green/Black- Ground continuity)
1 - 9 of 9 Posts
