1 - 2 of 2 Posts
Running a Power Commander, Full Akra exhaust on a 2009 600RR. Just got an 8 short flashes indicator from the check engine light and the bike started sputtering. I believe the coding is "throttle body position sensor" As anyone experienced this? What did you do correct this? Ive only had the bike for 6 months. Street rider and not aggressive. The power commander was disconnected up until 1 month ago and the issue just stared two days ago. Any constructive/informative input will be greatly appreciated...Thanks,
Yes,
I had exact issue.
3+ yrs ago. PC5 had been fitted about 6 months prior, and had put about 5k miles on it
09, PC5, full Arrow system, started throwing TPS error on MIL. (would go into limp mode)
I removed PC5 and rode bike .....no problems, no code.
Contacted DJet and sent PC5 to DJ tech service for examination/diagnostics.
Paid extra for "rush service". (total about $50?)
3-4 days later got a call from DJ. they had found it "defective".
Replaced under warranty, and no problems with it since.
1 - 2 of 2 Posts
