1 - 2 of 2 Posts
when my bike is off and i pull back on the throttle and let go it doesnt return to start position
when my bike is on and i pull back on the throttle and let go it does return
to start position
the guy at the bike shop said to try cable lube...i really cant because the cable is pretty much inaccessible
any suggestions?
i have a '03 600rr no mods
just take the switch housing apart on the handle bar and pop the cables out of their respective holders. should only need a screw driver and maybe a small adjustable wrench.
spray some cable lube down the cable and the cable tube. make sure the cables operate ok before you put them back into the holders (not kincked or pinched anywhere). then i'd put it back together making sure everthing is smooth to operate as i put it together.
1 - 2 of 2 Posts
