Well guys, I have been on here ahwhile and finally need help. I did search, but no avail. I have a 2003 and am wondering what the trick is to changing the throttle tube (grip and tube)?
I backed off the slack from the minor adjustments up top didn't seem like enough to take the cables out without forcing it. I am sure I can get the cables out if forced, but getting the new tube in would be another issue.lowlife said:grip is easy do search for grips and you'l come up with lots, basically, soap or compressed air or hairspray etc....for the tube, take the screws out of the switch housing, slack off the cables and take the cables out of the tube, reverse to install...
