1 - 3 of 3 Posts
So the fuel pump relay on my 06 600rr seems to start ticking about 10-20min after having been run, when the bike is completely off. This eventually drains the battery unless it's on a tender.
The relay has has three black and white wires going to it as well as a brown and a brown with black. While the bike is off and key out, the black and white wires still show 12v hot at the relay.
What the heck? Is this another ECM issue? Help!
Other than the random relay ticking, everything else works on the bike as it should.
similar problem, happened the 1st few time when bike was switched on, switched bike off and it was fine, yesterday heard the bike clicking when it was off, ran over switched key on then off and it stopped however, full beam and radiator fan are not working since. Think itss a bad ground, let me know if you figure it out.
1 - 3 of 3 Posts
