1 - 10 of 10 Posts
can someone give me the torque setting for the 2bolts that hold the front fairing & speedometer to the rest of the bike?? thanks.
I don't have the specs, don't really use them unless they're on important parts. I like to use loctite on everything, if you use loctite and a little bit of pressure you'll be fine.
N
Munkeeboy said:
Ii think most of the bolts on the bike are around 20lb-ft. Don't quote me on it tho.
Yeah, I wouldn't quote you on that.
Some are 9 lbs and some are 19 or 20 lbs like you mentioned, and some just require you just tighten them.
1 - 10 of 10 Posts
