1 - 2 of 2 Posts
Hi lads. I need to check the throttle position sensor on my rr3 is adjusted correctly. I brought a secondhand throttle body and it looks like it has been moved at some point because the paint marks don't match on the bolts.
Does anyone know what voltage I should be getting when the throttle is fully closed, and the idle is all the way closed. Doesn't seem to be anything in the Haynes manual I have.
1 - 2 of 2 Posts
