G
·What are you guys running for trackday rubber? Looking for track only wheels/rubber so no road work, all track.
suggestions? tia
suggestions? tia
I've been told that the Corsa III ties would overheat if one were to push them on a track. They heat up fast, and are more suited for agressive street use, not track UNLESS you are in a slow group. Since the 2CT tires are very alike, i'm not convinced that they would be a good tire to use on a track. Maybe Road America since it's just so damn fast but...OveRReV said:^^^^^^^^^ agreed, you should look at a street/track type tire like the Pirelli Diablo Corsa III, Metzeler Sportec M3 or Michelin Pilot Power 2CT, these tires are the closest thing you can get to a track duty only rubber & lasts longer which means more track time & a happy wallet, once you exceed the limits of these tires can give you you can upgrade to a track tire & appreciate the difference.
how many trackdays have you done?
Diablo Corsa III tires overheat? dude that tire is a spec tire for the World Superstock 600 class & they usually push their bikes hard in 15 or more laps, that tire is more track oriented than it's predescessor the Diablo Corsa. Pirelli techs recommend 31F 29R tire pressure for the track.Knightslugger said:I've been told that the Corsa III ties would overheat if one were to push them on a track. They heat up fast, and are more suited for agressive street use, not track UNLESS you are in a slow group. Since the 2CT tires are very alike, i'm not convinced that they would be a good tire to use on a track. Maybe Road America since it's just so damn fast but...
I can't do a ton of track events a year, since the only two tracks i know around here are Road America and Blackhawk Farms Raceway. Money is no object here as i'm lucky to do... 4 a year? maybe 5?
Knightslugger said:What are you guys running for trackday rubber? Looking for track only wheels/rubber so no road work, all track.
suggestions? tia
Good choice! Thats what I'm fitting next...Michelin pilot race 2CT. Im sticking to standard rim sizes/profiles- 120/70 front and 180/55.pantablo said:I run a slowA/fastB pace and have always just used street tires. Pilot Powers, Pirelli Corsa mainly. They do FINE even at a fast pace. I will be trying the 2CT versions next...
Try a 2CT Michelin, or Metzeler.Qwikk said:i'd like to hear more about the pirelli III's ....how are they?....i've always ran the corsa, then tried the powers because everyone and their mother raved about them......wow was that a mistake.....how do the III's compare to the corsas?
