1 - 11 of 11 Posts
i would think so. pretty good price too.. Does it come with a flooor or do you provide that. some diamond plate would be cool flooring with pretty good grip. Let us know how the bikes fit if you get it.
12" tires seems kinda smallish. no personal experience with towing bikes but i was told u should look to get 15". anyone here with exp wanna share your opinions?
cowboy600rr said:
here is a picture of the HF trailer w/ a 2 bike setup. i don't know how to make it any larger. sorry...
which trailer is that??? i mean, the weight capacity???
cowboy600rr said:
not really sure. it's not my trailer but i believe it's the 1175lb 4x8 trailer for $229, if i remember correctly.
Correct. I have the same trailer with an eRail system. It holds 2 bikes without problems. The 12" wheels work fine as well.
**If you're seriously considering...get the spare tire and folding ramp in one shot.
cool... so its sturdy enough that the trailer wont be moving around too much while driving??? and what type of flooring did u put on yours? just plywood?
No issues with it moving while driving. I used heavy duty 3/4" plywood. It's labeled hardwood at Home Depot. One sheet of 4' x 8' x 3/4" cut in half (4' x 4') is enough to do the job. Check this place out for the E track I spoke of. No need to permanently mount your chocks in one position. The adaptable chocks are not listed on the site but they're available. PM me if you need a pic of them.
http://www.etrailer.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=E&Category_Code=ET
1 - 11 of 11 Posts
