1 - 1 of 1 Posts
Well after searching forever to try and find what code 16 was on my bike and most trouble codes posts I found not listing it, I got a manual and this is what it says. Figured I'd post it to try to save some people a little time
1 Blink: MAP sensor circuit malfunction
-Operates normally
2 Blinks: MAP sensor performance problem
- Operates normally
7 Blinks: ECT sensor circuit malfunction
-Hard start at low temp
8 Blinks: TP sensor circuit malfunction
-Poor performance when moving throttle quickly
9 Blinks: IAT sensor malfunction
-Operates normally
11 Blinks: Vehicle speed sensor circuit malfunction
-Operates normally
12 Blinks: No. 1 Primary injector circuit malfunction
- Does not start
13 Blinks: No. 2 Primary injector circuit malfunction
-Does not start
14 Blinks: No. 3 Primary injector circuit malfunction
-Does not start
15 Blinks: No. 4 Primary injector circuit malfunction
-Does not start
16 Blinks: No. 1 Secondary injector circuit malfunction
-Does not start
17 Blinks: No. 2 Secondary injector circuit malfunction
-Does not start
18 Blinks: Cam pulse generator, no signal
-Does not start
19 Blinks: Ignition pulse generator, no signal
-Does not start
21 Blinks: No. 1 O2 sensor circuit malfunction (California type only)
-Operates normally
22 Blinks: No. 2 O2 sensor circuit malfunction (California type only)
-Operates normally
23 Blinks: No. 1 O2 sensor heater malfunction (California type only)
-Operates normally
24 Blinks: No. 2 O2 sensor heater malfunction (California type only)
-Operates normally
33 Blinks: E2-PROM in ECM malfunction
-Operates normally
-Does not hold self diagnosis data
48 Blinks: No. 3 Secondary injector circuit malfunction
-Does not start
49 Blinks: No. 4 Secondary injector circuit malfunction
-Does not start
1 - 1 of 1 Posts
