Hi all,
I just got my speedo healer (took me a couple months to finally get around to buying it).
I started working on it earlier tonight and have gotten stuck. There might be a few places where i might be going wrong.
I got the correct harness (SH-HO5 for the 2007 CBR600RR) and SpeedoHealer v4
I went ahead and removed the Speed Sensor coupler and even did the "Confirmation" that comes with the paper "Install Guide for SH-H05 Harness Kit"
I disconnected it and then followed: "Rotate the rear wheel while the ignition is on. Does the speedometer show 0, turn the ignition off and proceed to the next step" I even tested it before and had the ignition on and spun the wheel with my hand and the speedometer started to read it. So i know that i disconnected the Speed Sensor.
Are both connectors supposed to be connected? It is a bit unclear. So far i connect one connecter from the harness and then connect the other end of the harness to the Speedo Healer box. Should one of the connectors not be left unconnected? (refer to the picture above) I tried it by connecting both and nothing. When i go to test whether it is installed properly following these instructions:
"1. Have the ignition off 2. Pres SEL and keep it depressed while you turn ignition ON [t] (test) is now indicated. Release the button"
The speedohealer never turns on or shows me a t. The digit screen remains off. What am i missing?
If anything is unclear please let me know! My bike is in my garage right now taken apart awaiting the help of 600rr.net!
Sincerely,
A :cursin: and :retard: noob!
I'm new to bikes, i have a 07' cbr600rr. changed my sprockets and chain to -1/+2 and 520 chain so a speeadohealer is required. bought the exact same SH. I have no idea what to do as well, same question, the extra wire, where does it go?
I'm hoping someone on here has a clue what to do.
Thanks,
Dan
So I have a 08 model and used a SpeedoHealer. What you do is you connect one end to the bike from the little box and then you connect the other end to the sensor. So basically it acts as a jumper in between the two wires. Hope this helps. All it does is mess with the Speedometer and tricks it into thinking its going slower (or vice versa) so that your sensors and everything will be accurate. Hope this helps. I didn't do the 520 but I did do the sprocket swap for the torque.
hey bmac7599. i uploaded a photo of the wires. there's 3. would you happen to know where to plug them into?
One goes into the SH, one goes into the speedometer sensor. where does the other go?
