1 - 3 of 3 Posts
hey guys
im tryng to eliminate the o2 sensor.
im cancling it with the o2 eliminator that i got from ebay:
O2 Oxygen Lambda Sensor Eliminator for Honda Honda CBR 600 RR 2007 2014 | eBay
before the install i had these mods:
its 600RR 07 | 70k Kilometers
Two Brothers slip on
MJS mid pipe
dyno power commander 5
and than i had the FI code 23 ...
so i got the o2 eliminator from ebay
installed it , and still having the same problem FI 23.
tryed to delete the codes with disconecting the battery and than reseting the ecu with the jumping the wires in DLC :
http://www.600rr.net/vb/15-general-discussion/256685-2007-ecu-reset.html
even tryed to disconect the DYNO and delete the codes still having the same code fi 23...
by the way i checked the eliminator with multimeter it showed me 330ohm resistence
and tryed to do this "DIY" with only resistor and not the plug that i got from ebay :
http://www.600rr.net/vb/70-diy-write-ups/184998-diy-$-99-diy-o2-oxygen-sensor-eliminator.html
have no idea what to do
maybe anyone had the same issue and could help me
hey guys
MJS mid pipe
Have you by chance taken out the airbox?
yes i did .
but of course i returned everything to its original place .
after all this i melted into the MJS mid pipe a plug for OEM O2 Sensor to eliminate the eliminator :D
and still having the code with o2 sensor originaly conected...
1 - 3 of 3 Posts
