1 - 3 of 3 Posts
2006 honda cbr 600 rr no headlights cranks no start need help no relays bad tested everything had same problem two weeks ago took it to the shop and all the guy did was run a ground wire from the frame to the turn signal on the left front ran great then same thing again need help
Do you hear the fuel pump prime?
You say no headlights, does that mean the plastic piece the headlights mount to is off the bike?
Because this piece is where the tip over sensor sits. If that's not on right or plugged in the bike won't start.
Frame ground is on the left front and that's also where the tip over sensor plugs in.
The turn signal circuit has nothing to do with the bike starting or running. You could remove all the turn signal wiring and it wouldn't affect anything else.
1 - 3 of 3 Posts
