1 - 3 of 3 Posts
Alright, I put Bikemaster signals on my 08 600rr. They use a 12V 23W tiny bulb, one blew and I cant find any like that around my town. There are 12V 21W...would it be okay to use a smaller watt bulb? would it blow my fuse?
Also, my fuse did blow (the one for turn signals, brake light and horn), is it because I took the bulb out and left the empty socket then tried to use the turn signal?
Yes, the 12v 21w is standard - your Fuse will be fine.
Fuse may have blown at same time as bulb - it happens & is normal..
I'm assuming you replaced the Fuse with the same rating?
Yeah, I replaced the fuse with the same thing.
1 - 3 of 3 Posts
