1 - 8 of 8 Posts
Drop My Bike On Sunday 06 600RR (4200 MILES) And The HOrn And Turn Signals Dont Work. When I Put The Turn Signal On The Front Signal Will Turn Off. Front Head Lights Work And Back Light Is On. (intergarated Light In Back)
what side did you drop it on, and have you checked all your fuses?
Droped It On The Left Side Have Not Checked The Fuses. When I Use The Turn Signal On Either Left Or Right That Side Front Signal Light Will Go Off.
Check the fuses....I can almost bet you blew one...
if the fuese as all ok. Then obviously the next thing would probably be a pinch wire. I would check under the left ram air tube to make sure all the connectors on that side are ok. Any pictures of the damage so that we can give you a better "educated guess"?
1 - 8 of 8 Posts
