hey guys here it goes...
2006 600rr
Problem:
One day i was using my turn signal and notice the left indicator light ging weak..from weak it went to not comin on at all (along with all the left lights obviously). After a while the right wouldnt come on which i found out was because of the blown fuse for it. Changed the fuse and it just repeated again so it must be a short somewhere.
What i tried so far:
Changed the fuse which didnt work because it keep getting blown.
I pressed the rear turn signal indicator plugs on the left side where it comes out the side and the left would then work if i pressed it in a certain way..The plugs are securely in so i dont see why it did that.
ideas why the fuse is getting blown?
The wiring appears ok to me. Could the relay cause this because its faulty?
Also, not sure if this may be a cause because of heat, but my Front turn signals are mounted on the radiator for now because i dont have my upper cowl yet
Thanks
Sounds like you have an intermittent short somewhere. Check the wiring for any cuts in the insulation or any melting that exposes the wire to the frame. Did you install the lights yourself? Do you have resistors in there that could be shorted?
I bought the bike with the lights.
But that was over a year ago. I have a feeling it may be melting to the frame somewhere. ill have a look
ok so i chcked it out and the wires look fine. Took it for a ride yesterday and the lights worked fine until the temp got to normal running temp..bout 180 then thats wen the left light started acting up..turned the bike off and as the engine cooled the light was fine..until i rode again then it went out then the right side went out about 15 mins after the left because of a blown fuse
Could it be because i put the flush mount signals up front on the radiator?
