1 - 2 of 2 Posts
To start off i have led turn signals in the front and a integrated tail in the back... i have the customled flasher and everything was working fine
i got into a accident and currently there are no fronts hooked up but the back turn signals were still working. In the process of hooking up a streetfighter headlight i think i shorted something and blew the fuse for my flashers and brake light and brake light because they werent working at all
found the fuse was blown, replaced it and now when i turn on the signals they dont flash just stay a solid color... is it possible to have wrecked the customled flasher somehow?
K
crashes are pretty unpredictable. test the unit if you think it's bad. otherwise you may want to look into the switch.
1 - 2 of 2 Posts
