1 - 3 of 3 Posts
Hello all,
I am currently having a problem with my turn signals.
When you turn the bike on, all turn signals turn on and stay on. When you select a direction the lights will blink till you "cancel". Once "cancel" the lights stay on.
This was an existing problem with the previous owner. He must have been the smartest person in the world and cut off all the original "clips" to install his aftermarket turn signals. I have temporary wired them back together using a wiring diagram. i belive they are wired correctly but i could be wrong.
What am i doing wrong, i'm driving my self crazy
Attached is a short video of the problem, sorry for the poor quality, but i think it get the point across.
Thanks :cruising:
Cut the wire with the tracer on it.. You can't have running/signals with a 2 wire turn signal or get some diodes and wire like shown. If you have it wired correctly then your flasher relay is dead and you need to do this.
http://www.600rr.net/vb/showthread.php?t=114102
1 - 3 of 3 Posts
