1 - 1 of 1 Posts
I have a carbon fiber black series slip on system from TWO bros, and everything went well in the install, EXCEPT the down pipe sits too loosely over the header assembly and the clamp that came with the exhaust doesn't tighten up the slack that's there. You can tighten the clamp all the way, and the exhaust will be able to wiggle off very easiy. Has anyone had this problem? What did you do to fix it?
1 - 1 of 1 Posts
