1 - 2 of 2 Posts
Where in-store can I find tygon 2075 chemical resistant tubing to use for brake lines? Or what can I use? Currently for my rear brake res. Delete mod I am using clear vinyl tubing from the hardware store but it is sweating brake flux and the tubing is getting very soft. Where can I find some clear tubingthat will work for my brakeline. I Dont want to order this online as I need to do it this weekend. Thanks in advance guys.
dude,
i wouldnt play with brakes like that. Its not so much the hose but the connector that i`d be woried about leaking.
If you can get to a hydraulic hose shop they will have hoses that arent affected by the brake fluid AND most importanlty they can clamp the fitting to the ends of the hose.
1 - 2 of 2 Posts
