Hey all,
Ive thrown in a US ecu to by pass the hiss system on the bike, i have finally got the bike started and the fuel pump priming connecting the extra grey wire onto the white connector plug and conneecting it directly to a external 12v source following a wiring diagram and watching a youtube video. Thou i need to know where i can tap into for a 12v power when I have the bike switched on so the pump runs too. Does anyone know where i can tap into to get 12v power with power switched on
Sorted out, incase anyone searches this thread, that pin added needs 9v so you will need to attach a zener diode and plug from any 12v source on the bike,
That depends on the year model of the ECU you've used. The zener is only needed on the 03-04 ECU.
Hey Nico,
I made a youtube video on how to work a non hiss ECU on a australian harness and how to get it working
Good job mate, quick tip though - stop using your kill switch or it will fail. Really common fault with them.
