1 - 20 of 20 Posts
Impreza The Impressive
I bought this
And wanted to know if this would work? Also, if i use too much, will it drip into my oil and cause problems? Thanks
no, there's no crack. I took it off to get powdercoated and want to put back on. Do i even need to seal it to put back on?
Due to bad experienceS I do not trust epoxy for nothin'! Be careful man.
NOOO.... dont use that stuff
Use either hondabond at dealer or permatex ultra black/grey rtv gasket maker at autozone...
if you use epoxy you will never get it off..
Red RTV mang
if ya use epoxy that cover aint comming off anymore
use high temp RTV......epoxy is like superglue times 100000. dont use it. itll seal up and you wont be able to take it off.
ok i won't use it. but i did go buy Ultra Black hi-timp rtv silicone gasket marker. how should i use it? any advice?
put on as thin a layer as possible. use a knife or razor of some kind if possible. it doesn't take much...at all.
A q-tip works well when applying.. Just make sure there isn't anything on the back.. left over sealant, just use a razor to clean and wipe it down.. Thin coat, you don't want it to come out the sides when you put it on..
yeah you want to get the two mating surfaces clean first. no it doesn't need to be warm. it sets up pretty quick so dont wait too long to mate the two after it is applied. also you only need to put it on one half (cover side is easier, imo).i waited a couple hours and then put the oil in, no leaks.....yet ;)
Discussion Starter #14
im afraid that i might put too little and it won't stick as well and i'm afraid to put too much because it might drip into the oil and **** something up. thanks for all the help =)
Is part 5 and 6 necessary? i only have part 5, never saw a part 6. And is that the way it's suppose to go in? not washer in the inside of part 4? thanks
your pic is correct, that is the order they go in. shows the same in the repair manual. i dont know their individual importance, tho. good luck
1 - 20 of 20 Posts
