1 - 2 of 2 Posts
Using an 07 RR in a Mini Sprint. We've typically run the Yamaha R6 carbs on them, but we're setting one engine up w/ injection.
Have a question on vacuum lines- 2 sets off the back of the throttle bodies - lower set goes to MAP, the upper set goes to ??? Emissions control? This engine was a 'car kit' so not everything was included. I think for our application, we'll likely be capping them, but just wanted to double check the bike's application.
Any help appreciated.
BLT
The 07rr has an idle air control valve.
There is a line running from the airbox to a solenoid and then from there to each throttle body
The map sensor has a small line running to the airbox. Its not a 'set' at all.
1 - 2 of 2 Posts
