1 - 10 of 10 Posts
Rolls over and over has a smell of gas while trying to start and kicks a couple times like it wants to,
-Tried jump starting
-Tried charging batter up
Crossed the wire that shut it off when dumped
Checked nutral sensor
Unpluged kickstand sensor
Tried doing the 5 second wot while rolling ove
Ganna change the plugs and fuel amd oil but stumped so far.
He parked it running But was in a non heated garage,
That's what I'm thinking it is im waiting on plugs in the mail and had started taking them out lastnight but got called into work, figured while I have them out mise well change them
Did you jump the bike with the car running? If so, you probably blew some fuses. Worst case, I believe doing that can fry your regulator/rectifier.
You can test this with the old plugs. And as for jumping with the car running it SHOULD blow the main fuse before doing any damage, check into that as well if this was the case. It's located next to the battery in a rubber sleeve.
Was there any work performed on the bike recently? If so, I would check to make sure all sensors are plugged in. I had the same thing happen to me and i missed a sensor when I was putting it back together.
Never boosted it with a car, just fully charged with a trickle charge, and it was parked running and hadn't been touched until now, everything seems to be connected I got all fairings off and havnt came across anything not hooked up
Yes I figured I'd just put new plugs in while I have the old ones out to check for fire, working a long shift so won't get back to finish it for a couple days :/
I know my dirtbike wouldn't run after sitting for a couple months, it would sstart and just stall because of old fuel even tho it didn't sit long changing it fixed it right up, hasn't had any ppreservatives added before storage
1 - 10 of 10 Posts
