1 - 3 of 3 Posts
I'm replacing the clutch cover on my 06 cbr600rr, on the starter gear there are supposed to be a wave washer and thrust washer, initially I saw none, but when I pulled the gear out the washers are on the back side, are there supposed to be 2 sets of washers (1 set on the rear side of the gear and one set on the front side) or are they installed wrong and do I only need the washers on the front side?
Thanks man, I believe the previous owner put the gear on backwards, so I switched it around and put the washers on the outside, looks much more accurate now
1 - 3 of 3 Posts
