1 - 17 of 17 Posts
IS GHEY FOR PHATTY!!!
My water pump has stpped working... what runs it from the engine? And is this going to be a drop the engine job?
D
It's powered by the oil pump shaft and is not a drop the engine job. If the oil pump is working, there shouldn't be anything preventing the water pump from working outside of it just being bad, or a clog in it.
first the stealership said the thermo was not openig and now it's working fine but the water pump in not... is this something i can do by myself?
D
How do you know the thermostat is actually opening? But yes, you can change the water pump yourself. It's not too difficult to do.
going off what the dealership is telling me... bike was running at 270 degrees
thats way to hot. do the red neck test. just dont run it to long like that. make sure you take the upper hose going to the radiator out. thats the return line i believe. and if it gushes out water, then your pump is or should be good. i would go with the easy stuff first, replace the thermostat.
D
Well, if it got that high, you should replace your thermostat anyway since it's probably FUBAR'd.
thanks for all the info guys... it take the effen dealership a week and a half and $500 to figure anything out and everyone here 2 days... i'll keep u posted
oh and this all did start happening after a a pretty brutal low side last year to the right side of the bike... a tight turn plus a stiff front does not end well in gravel
D
Was only the right side of the bike damaged in the crash? The water pump is on the left side of the bike, so if there's no damage over there, it could also be possible that the oil pump drive chain/sprocket behind the clutch case on the right side could have become damaged, loose or the chain came off.
Discussion Starter #11
we checked everything on the right side... cosmetic and some wires we had to fix... oil pump is good... had a clutch case cover and there was no damage (although the gasket has a barely noticable leak in it, takes a week of sitting to get a drop on the concrete and only when leaned over)... the gilles rearsets did help protect some from too much... 90% of the damage was at the upper front
D
Probably is just a worn out water pump or something clogging it than. Shouldn't take more than 30 minutes to pull it off.
that what i figured but know dealer time is that plus whatever they feel like adding
D
At a dealership, they'll probably charge you 1.5-2 hours labour, plus shop supplies and a gallon of coolant. Somewhere between $150+$250, excluding the price of the water pump. Best to just do it yourself.
agreed :banghead:
What year is it ?
Before you rip the pump off.. Have you had a good look at the top metal hose which is behind the right mid? (from the motor to the filler neck) It may me crushed, causing a restriction. The metal pipe is covered with a plastic sleeving that hides the damage. Worth a shot..:banger:
1 - 17 of 17 Posts
