Is it safe to use Water Wetter for street use in a climate that never gets anywhere near freezing temps? And if it's okay, I've read that you should flush it out once a year. Is that true?(I ride almost everyday year round by the way)
IIRC from past threads OTF.......WW doesn't have corrosion inhibitors.
thus, change of coolant is a good idea annually as coolant can become corrosive over time.
check race and track forums...use search...OTF
I would stick to normal coolant with corrosion inhibitors, otherwise the internals of your motor are going to fur up and rust.
Ran Water Wetter on and off track for years with 15% antifreeze as recommended. After each flush the coolant became white, losing all its colors.
You can use it but just need to flush it more often and be sure to add 15% antifreeze coolant to the mixture as recommended.
